Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
BMW Roundel Oil leaking from folds in heat tray above turbos on N54
After 2 VCG changes and a VC replacement, I'm still getting oil pooling on the metal heat shield/tray above the turbo. No visible oil leak observed, the oil just starts pooling up and out of the folds in the metal tray. Oil then leaks onto manifold and cat which leads to smoke coming from those areas. Where could this oil be coming from? I've seen other forums which other N54 owners have had the same issues but no resolution. Help needed, please.
Old 06-16-2017, 09:50 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Tags
n54 , oil leak , oil leak after vcg change
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
