Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
e93 M3
E93 S65 M3 car shakes first 5 min after cold start
Hello everyone. Before I take it to the shop, I wanted to see if you guys know what DIY fix I should try first.
The problem:
My E93 M3 car shakes for the first 5 min after cold start. It stutters front to back, not left to right, during constant speed. I would shift into 2nd or 3rd and set the cruise control for anywhere from 20-30 mph and let the car go at constant speed and it would stutter. Everything in the dash looks fine. No bad idle. No warning lights.
After driving for 5 minutes, everything is super smooth.
Anyone have an idea what could be causing it?
Thanks all.
Joey
Old 08-09-2017, 06:58 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Joey - if you're able to pull the codes first, I would recommend doing that before bringing it to the shop. The stored codes should give you a definitive answer as to what is going on and where to start troubleshooting. Best of luck!
Old 08-10-2017, 10:21 AM
e93 M3
I went to Pep Boys and they plugged into the OBDII port but did not find any codes. I guess it's a good thing but now I'm still unsure what could be causing the stuttering.
Old 08-26-2017, 07:04 AM
got it.
A ISO/TS16949 certified OE manufacturer of Auto Parts since 2004. Producing fuel line, oil cooler, water outlet/thermostat assembly, coolant water pipes, all kinds of tube/pipes. Website & Page: www.fb.com/021auto
Old 12-27-2017, 06:42 PM
