Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
mgatepi's Avatar
BMW e30 no start
Hello All,
I am attempting to start my BMW 1990, 325I after being stored away for the winter. (I know wrong forum, but this forum is much more frequented than the BMW forum) The car cranks over no problem. I thought perhaps the plugs were fouled so I installed a new set....still no good. After numerous attempts I pulled a couple of the new plugs out and they are dry...dry as dry can be. So I am thinking no fuel, I loosened the fuel line going into the regulator and rail and there is pressure and fuel there.
So....what is going on? How can I have fuel at the injector rail and none in the cylinders?
What do I need to check??
Any input is highly appreciated!!!
Thanks!!!
mg
1983 911SC "The silk purse"
2017 Lexus RX, 2017 Acura MDX
1930 Cadillac V8, 1991 Ford F250,
1988 BMW M3
And ZERO garage space!
Old 03-30-2018, 05:59 PM
franklinstower's Avatar
Check the muffler bearings
'78sc coupe / 89 Westy - EJ25 frankenmotor
Old 03-30-2018, 06:18 PM
go over to r3vlimited for all your e30 needs
Old 03-30-2018, 06:24 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Pull an injector and see if gas squirts out of it when cranking......
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-30-2018, 06:27 PM
mgatepi's Avatar
1) replaced the muffler bearings last fall so should be ok.
2) Been there
3) No squirt, but why?
1988 BMW M3
Old 03-30-2018, 06:38 PM
Eng-o-neer
Tremelune's Avatar
Not to try and boot you off the forum, but those recommendations are sound:
https://www.r3vlimited.com/board/index.php
pelican:911::r3vimited:E30
Old 03-30-2018, 06:48 PM
I had the same Sympton when I put an ej22 into my vanagon, it ended up being a bad ground in the harness. So the injectors were'nt firing. Can you check power at each injector?
Old 03-30-2018, 06:51 PM
mgatepi's Avatar
I believe I have a bad fuel pump or fuel pump relay!
mg
1988 BMW M3
Old 03-30-2018, 07:06 PM
Formerly known as Syzygy
Canada Kev's Avatar
Happened to me with my E46 325. Was running fine, stopped to grab a sandwich and it wouldn't start after. Bad fuel pump.
Kevin
Old 03-30-2018, 08:32 PM
porschetub's Avatar
Yep fuel pump or most likely the relay,don't worry about the other silly comments everyone has to start somewhere,the fuel pump relay is more common failure wise but if the car has been sitting the pumps tend to gunk up,check the power connects to the pump ,Bosch pumps are voltage dependant and need 12V to work ,good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 03-30-2018, 10:13 PM
