-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   The never ending lean code (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/1023541-never-ending-lean-code.html)
Dvangrush 03-13-2019 02:41 PM
Po171
174. Bank 1 and 2 lean
Changed turbos
Valve cover and gasket
2 smoke tests performed.
No air duct leaks from what I can see
New symptom only once 29f1 (fuel pump plausibility ).
Not sure if that’s the fuel pump or something else causing the pump not to work properly.
Anything helps. I need an expert on e60 2008 535xi.
