Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
E39 540iT no crank, no start
I have an E39 year 2000 540iT with automatic transmission with a no crank no start issue. I've scanned with BMW P.A. Soft which resulted with the following errors:
EGS module: 53(083)ECU internal error 4 (FETI), also 22(34) sump oil temp. sensor
LCM module: 59(89) Transmission failsafe program
IKE module: FB(251) no CAN message (EGS1)
EWS module: no errors, however this from live data: starter enabled-gearbox in P/N = NO (red box)
The car will crank and run by putting the ignition key in the second position and jumping the starter terminals. The ignition switch has had all contacts cleaned and appears to be in good working order. The ignition key is recognized by the EWS and all fuses in the glove box are good.
Do I have a bad EGS module? Is there a relay for the EGS that could be faulty?
Any advice would be much appreciated!
Thanks much,
Richard
Old 03-23-2021, 06:57 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
