Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Unhappy "crank but no cigar"
2007 BMW 525i 5 Series E60 N52,while driving at a low speed felt as if the engine wanted to cut off so i pulled over put it in park and gave it a little rev. It seemed to work and it cleared up BUT moments after i had shut car off and went to restart,crank no start. Its been sitting for 6 months and during that time,are you ready for it, I've replaced battery,IBS,starter,alternator,spark plugs,ignition coils,valvetronic,fuel injectors and fuel pump.CRANK NO START. I now have ISTA+D & INPA but little to no exp in using it but I am working on that. Anyways,I had MANY faults not only as a person but within my car but managed to bring the number down. Following fault codes are stored for tested function or component group.
DME control unit
2E30
2E31
2E32
2E33
2E34
2E35
Also fault 2DED
DME:Power managment,closed circuit current violation
9CB9
LM:Battery exhausted
A8BB
LM:E60 right clearance light faulty
I just recently replaced a few relays in Ebox under hood that did have water damage and blah blah blah im tired of hearing myself type. Apologies.
Old 12-10-2021, 01:57 AM
Tags
2e35 , 525i , crank no start , e60 , fault code
