Automatic Windshield Wiper Sensor Adjustments
Being a Newbie to this forum, I hope this isn't a question that has been asked 1000 times before.
I have a 2000 540i on which the automatic wiper setting does not work. When set there, it cycles once, and then never again. The windshield is clean, and I have tried both with and without RainX on the sensor area. My questions is if this is something that can be adjusted, and how. Thanks! Steve |
Do you have a rain sensor?
If you change the speed of it while activated, does it wipe again? Cheers |
Nothing happens regardless of speed and position of the 'sensitivity' dial on the stalk. Nothing happens even if I spritz water on the window over the sensor by the rear-view mirror mount.
The wiper first fires when the stalk is moved to the auto position, but nothing after that. Steve |
Sorry I didn't see the sensor part. I'm "guessing" it's a relay issue, but call a dealer or known wrench and ask them to fax you details on this service bulletin:
611300 OCT 00 Windshield Wipers - Various Malfunctions Maybe it will help. |
I have the same problem with my 530 I please let me know the solution
at email; johnnyblue3@canada.com |
| All times are GMT -8. The time now is 10:12 AM. |
