-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Trans Program Reset? (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/152761-trans-program-reset.html)
bmwman525 03-10-2004 06:57 AM
I have 92, 525i with 215,000 on it and it has a transmission fluid leak where the rear seal is.
I had the pan gaskets replaced and the trans filter about 6mos ago. The fluid was low so I added fluid and was on my way to a lube shop when the car reved and would not go into gear. Then the "Trans Program" appeared on my dash. I puttered to the shop and had them top off the trans fluid. It was about 1.5 qts low. So how do I reset the "Trans Program"?
Are is it to late to save the transmission? I tried disconnecting the battery for several hours.
BMWCowboy 03-11-2004 06:00 PM
Sounds like you need a new transmission>>You need to go to a BMW shop to clear your fault memory
