throttle problem ????
2001 530 ....starts only with throtle open,
idles fine when push gas pedal engine dies. car mowes forward only with throttle half open... please help happen after gas fill up at station
2001 530i black 2005 dodge ram hemi sport P1445 Big Hawg |
last minute update: ses light on
coolant low new radiator (10000 miles old)
Is it smoking?
Low coolant and really poor performance are a sign of a blown head gasket. The engine starts to suck water and it runs bad. Other symptions are: 1) Bubbling in coolant overflow 2) Milky white engine oil 3) Severely fouled spark plugs 4) Lots of white exhaust, or even antifreeze dripping from the exhaust If you get it fixed quickly, it's generally not catastrophic. The longer you wait, the higher the repair bill will be. This isn't caused by bad gas. Sometimes these just go bad. |
In the shop at Pelican
Im kind of thinking the same thing...
Maybe you should do a compression check. This can usually indicate if you have a blown head gasket. and run the codes on the car to see if there is anything wrong |
time to visit dealer......again
verdict:
camshaft pulse gener.......$242.60
Weird that you got the low coolant light. Sometimes cars don't make much sense.
Glad you got it back and that it wasn't something more serious. |
a bad cam sensor wouldnt cause you to lose coolant..
one more think.....car it`s a beast now !!!!
