Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Brake rotor replacement
I'm wanting to replace the front and rear rotors on my E39, 528i (1999). I'm not having much luck locating instructions. Does anyone know of a web page with the info? Most of the ones I've found reference installation of aftermarket enhanced product that require modifications. I just want to install OEM type equipment.
Old 12-04-2004, 06:24 AM
It'll be legen-waitforit
stealthn's Avatar
I would pickup the Bentley Manual if I were you. If you want some good info, but not exactly what you are looking for look at www.bmwtips.com
Good luck
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 12-06-2004, 08:43 PM
Very easy to replace-->remove wheel...remove brake caliper->2 bolts
then remove 1 allen bolt holding on rotor
Old 12-26-2004, 07:43 AM
