Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
BMW Roundel Help - Water Pump Broken Impeller
Hello All
I'm new to this forum but I would appreciate any help I can get.
I have a 94 525i, the issue with the plastic impeller became apparent to me when my car over heated due to the plastic impeller failure on the original OEM water pump. The problem I have now after pulling the pump out is there seems to be plastic chunks missing from it since it broke inside the pump housing. I could not retrieve them as they are not anywhere to be seen. What will that do to the engine if I do nothing? What options do I have in order to flush them out of the engine and how would I go about doing so? Any help/advice you can provide is greatly appreciated. Your site one of the most helpful sites out there and folks like appreciate that very much. Thx in advance.
Zghost
Old 06-28-2005, 07:55 PM
Take off ur coolant hoses & flush with water hose....flush radiator & motor
Old 07-07-2005, 02:47 PM
uscharalph's Avatar
Doesn't most stuff end up in the radiator?
Ralph - Marina Del Rey, CA
BMW 525i E34 (M20)
Old 07-20-2005, 12:53 PM
