Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
What's Facebook?
turborat's Avatar
e34 alarms
Greetings. I own 2 E34 cars. A 1995 540 Sport with the alarm built into the DME and key. The other, a 1995 525iT with factory add-on alarm under the rear seat with separate remote units. Both alarms will not work properly near commercial areas. Often they will not arm or worse, not disarm causing real problems getting the car started. I assume the problem is caused by interference from retail store security, etc..... Anyone have similar experiences and have a solution? Thanks Paul
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 11-19-2005, 06:42 PM
