-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Odd "Flapping" Noise up front (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/307015-odd-flapping-noise-up-front.html)
PeteLech 09-29-2006 08:10 AM
My 1995 525i , with 100K miles, has developed an odd "flapping" noise from up front. It sounds like a speedo cable that needs lubrication, but I seriously doubt that this car has a speedo cable.
It only occurs between 60 and 72 mph, and does not vary with the car or engine speed, or wether you are accelerating or decelerating. We looked under the car while on a lift, and could see nothing. I had hoped fo find a plastic bag stuck in the rear of the engine, but no such luck.
77landcruiser 12-04-2006 10:48 AM
Pete, We had a similar problem with our 2002 530. Our issue was two smaller sized plastic panals under the car near the fron doors. The panals are thin in the middle and broke and flaped under the car
at free way speed.
Good luck
4re308 12-04-2006 01:53 PM
I too have this strange noise. It sounds like it is coming from under the hood, and it does sound like a small piece of plastic flapping about. Annoying as heck.
BMWCowboy 01-07-2007 06:16 PM
Easy fix~~>TURN UP THE RADIO!!:)
PeteLech 07-27-2007 12:24 PM
Problem solved: It was the molding on the passengers side of the windshield lifting up because the clips holding it on broke. To test, tape it up with masking tape and see if the noise goes away.
You cannot replace the molding without removing the windshield. As the car had so 100K miles and the soft German glass was pitted, I put in a new non-german windshield.
Voila, I can see again.
Lets see:
Plastic water pump - broken 60 K miles
Plastic radiator - broken 82K miles (warped head)
Plastic Windshield molding -broken 100K
Plastic credit card - broken.
