rebuilding engine, need torque specs
E39 BMW 523i with M52 engine, i'm in the process of rebuilding the engine and i need the following info:
1)what measurement of the piston rings clearance gap? 2)what is correct cylinder head torque specs? 3)what is correct torque specs for main bearing and connecting rod bearing? |
thank you
np
| All times are GMT -8. The time now is 07:12 PM. |
