-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Fault codes - how to read - '95 525 (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/403691-fault-codes-how-read-95-525-a.html)
damir 04-13-2008 02:36 PM
Hi
On our '95 525 the old trick of pressing the pedal 5 times and getting the fault codes via "Engine Check" light does not work. I have done it many times and no joy. (On my 635 I had not troubles reading the codes). I have checked the gas pedal switch by validating the the car downshifts when pedal is floored.
So two questions:
1. How can I find out what the trouble with the Error Code display is?
2. Is there a low price OBD 1 code reader on the marked that can read the codes that interfaces with the large connector in the engine?
Don SmileWavy
Gus540i 04-14-2008 05:10 AM
error codes
Did you depress the brake pedal 5 times quickly? Are you not getting the "1000" default signal?
damir 04-14-2008 10:30 AM
Error codes - check light
Hi GUs
The Check Engine light does not even flicker after depressing the gas pedal 5 times very quickly past the "downshift" switch. The key is in the ignition, the ignition is fully on, the indicator lights are all on, etc.
Don
