Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
1998 528 won't stay running
1998 528i automatic
was running errands, all was fine, went home. 10 min later I went to start the car, it cranked, started, ran at idle, pressing the gas pedal had very little affect on engine speed. could not go past 1,800 rpm. went to bed.
next day, engine at ambient temp, 75 degrees, attempt to start car, it cranks fine, catches, I let go of the key, and within a second it stops running, throttle has almost no effect on speed of engine.
any ideas?
John
Old 08-08-2008, 04:21 PM
Gus540i
No run situation
Are you sure the key cylinder to start the car is functioning correctly? I'd start there
Old 08-12-2008, 12:09 AM
