Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
ruff idol (when cold) and hesitation
I'm new here... I have read past posts and it has been a big help... however still having issues...
90 525i M20 119k
I bought this car 3 weeks ago.... drove it 3 miles and it overheated.... found that it was the water pump that self destructed (plastic impeller)..... after overheating I took it down to the head gasket... then had the head tested and milled (out 5 thousands)
While I was there... I replaced the timing belt, water pump, belts, hoses ect.. new plugs...
Put it all back together an when cold it has a ruff idle until at operating temp... and a really bad hesitation when accelerating.... I have checked all the vacuum hoses that I can find.. fixed a few leaks and things have been better but still not right....
I have also checked the MAS, TPS, idol control valve, intake hoses +++, I have also done the carb cleaner spray around the intake and hoses.... but still have the problem....
HELP!!!
SEOguy
Old 11-23-2008, 08:11 AM
