Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Brake sensors e39 1998 540i touring
I have done the deed and bought an e39 Ordered my Bentleys and am about to order rotors and pads. How many sensors are there and are they likely to need replacing - not expensive items but why bother if it is unlikely to be necessary - in fact is it easy to fit them after re-assembly of rotors and pads? Any real benefit to drilled rotors and maybe harder pads. It is not that I do any track work, but I live at 3000 ft and there are a lot of hairpins.
Thanks!
Old 03-09-2009, 12:24 AM
shogun's Avatar
you mean brake pad wear sensors?
here you find the numbers, usually 1 front left and one rear right
http://bmwfans.info/
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 03-12-2009, 05:35 AM
shogun's Avatar
Brake Pad Wear Sensor; Front; 840mm 34352229018
Brake Pad Wear Sensor; Rear; 550mm 34351163066
provided it is an E39 528i from 1997 which I selected as you did not give any engine, month and year of production info
Old 03-12-2009, 05:38 AM
I'm sorry - it is a '98 540i M tech.
Old 03-12-2009, 10:03 PM
