Can I use a E28 528 starter on a E28 535?
Does anyone know if a starter from a E28 528 will work on a 1987 535is? Or does the starter have to be one for a 535?:confused: I am trying to be a cheap ass and buy a started at Pick a part and it is almost imposable to find a 535.
apparently not. I selected the part number of an 1987 535 with manual gear, left hand drive and the starter part number I then pasted into the cross reference and it shows these other cars
http://www.realoem.com/bmw/partxref.do?part=12411272150 Part Cross-reference Part 12411272150 (Rmfd- STARTER MOTOR) was found on the following vehicles: E12: Details on E12 E12 528i Sedan E12 530i Sedan E23: Details on E23 E23 733i Sedan E23 735i Sedan E24: Details on E24 E24 630CSi Coupe E24 633CSi Coupe E24 635CSi Coupe E24 M6 Coupe E28: Details on E28 E28 533i Sedan E28 535i Sedan E28 M5 Sedan E3: Details on E3 E3 2500 Sedan E3 2800 Sedan E3 2800Bav Sedan E3 3.0S Sedan E3 3.0SBav Sedan E3 3.0Si Sedan E32: Details on E32 E32 735i Sedan E9: Details on E9 E9 2800CS Coupe E9 3.0CS Coupe So maybe the easiest is one from an E32 735 which also has the M30 engine. |
Thank you, I need to print those out and hit up the junk yards.
| All times are GMT -8. The time now is 12:51 AM. |
