-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Ambient Temp Sensor Problem (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/557933-ambient-temp-sensor-problem.html)
David Lambert 08-09-2010 05:12 PM
I ripped the wires out of the connector for the ambient temp sensor. Replaced the
connector w/ new wires, however the temp display still reads -40. Also, the A/C
has not worked since damaging the connector. I have energized the ignition and
left it on for a half hour w/ no temperature change. Could the temp sensor have been damaged when the wires were yanked out? No visible damage is seen.
All thoughts appreciated.
Dave
tghtsqze 08-10-2010 05:53 PM
Dave,
You need to plug one in and see, did you solder the connections or crimp? make sure the wires are not touching each other in the harness.
