Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Need ignition 12 volt under hood on 528I
I have a 2000 528I and I need 12 volt under the hood only when ignition is turned on.
Can anybody help me with my problem. I like to avoid going to the ignition switch and run an extra wire.
Old 06-28-2010, 04:55 PM
Have a look at your diagnostic data port (the techo words for the pacman under the bonnet. ) I think it's pin 14 (check with a meter) that is +12v. If the central pointer is at the bottom it should be the first hole clockwise from 12 o'clock on inner ring.
Good luck.
Old 07-13-2010, 09:42 PM
Thanks, the car is in Florida and I just returned to play with it.
Old 01-15-2011, 06:59 AM
