Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
g partida (guest)
Guest
Posts: n/a
I replaced the brakes on may 528i. 2000. And the dach light won't go off how do i reset it.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Resetting BMW Airbag Warning Lamps (SRS Reset)
Old 03-02-2011, 09:59 PM
Author of "101 Projects"
Wayne 962's Avatar
The brake pad sensors control this lamp. If the sensors triggered the lamp to begin with, then you must replace them (they are one-time use only). If they are brand new sensors, then the connector is probably not well seated in the plug. I would unplug and then replug in all of the sensors to make sure the connection is good.
- Wayne
'79 911SC TARGA
CROWSC's Avatar
Wayne is right on the money, I just did my brakes and had the same problem. Replaced the sensors and all is good now.
CROW
'79 911SC TARGA
'05 BMW 525i
'98 HARLEY HERITAGE SPRINGER
'11 Ford Edge
Old 03-03-2011, 03:03 PM
