Guest
Posts: n/a
dear wayne i have a 1995 bmw 525i that i just replaced the radiator the water pump thermostate and clutch fan on and the damn thing is still blowing cold air and sometimes overheats i have bled the system and still nothing please help
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3-Series E36 Cooling System Flush |
Author of "101 Projects"
Blowing cold air instead of hot air through the heater? Sounds like a broken heater valve, or a massive air bubble in the system. I'd bet on air bubble. If you are having trouble bleeding the system by normal means, you can try pulling a vacuum on the system using a port attached to where the radiator cap fits. This is a standard procedure for Porsches, but it can also work for other cars that are having issues. Also try bleeding the car many times, at cold and warm too. It's probably just a bubble in there. Make sure the heater and fan are set to ON when you bleed.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
