Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
912UK's Avatar
Can't open the glass hatch on our touring car
Hi I can't open the rear glass hatch on our newly purchased BMW 5 series Touring car..
I knew that when i bought it I was hoping it was a simple ish fix..
The car is 2002 I can see a switch under the wiper housing that makes total sence it's for opening the glass section but does not work
Any tips hints of interest please let me know
Too many cars too little time..
Old 08-25-2011, 01:43 AM
Decolliber's Avatar
Lock actuator fuse?
Or maybe it is out of adjustment. See e39 Bentley pp. 412-22 to 23. It tells you how to adjust the locking pin.
When tailgate on wife's Subaru would not open, I pulled the cover off the latch mechanism and sprayed lubricant into it, and it has worked ever since.
John C
1988 911 Carrera coupe
2002 BMW 530
Old 08-25-2011, 12:28 PM
The switch maybe bad or if it is like mine you have to squeeze like hell to get it to work.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 08-26-2011, 10:50 PM
912UK's Avatar
Yeah I belled back the wires had to strip out a ton of plastic trim !!
a boot full infact..
to find it was infact a Faulty micro switch £28 from Main dealer and it's working again now..
All fitted back in place and working to demand perfectly..
Old 08-27-2011, 02:59 PM
912UK's Avatar
Item number 12 on the BMW parts list
mare of a job to take apart esp the wiper arm !!!
Old 08-27-2011, 03:00 PM
I hope that when you had it apart that you lubed the wiper shaft with grease that will save you problems later on, most peple replace the assembly but if you go through the disassemble you can just clean and regrease.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
Old 08-27-2011, 10:28 PM
