Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
robse34's Avatar
Cooling system overhaul
Just completed my 94 E34's cooling system refresh. New radiator, water pump, thermostat, hoses, pulleys, etc. The original radiator made in 287K miles; figured it was time to replace.
Parts from Pelican
Everything back together
Thermostat was broken
Old 09-28-2010, 04:16 PM
Wow, that radiator made it 200K more than most! My expansion tank failed with catastrophic results at 80K.
Pete
1997 Carrera S
2006 Carerra S Club Coupe
2011 BMW 328I
Old 09-29-2010, 03:09 PM
Correction: After working all afternoon to replace the expansion tank on my 525i, I learned that the previous failure was the radiator (top) outlet, which is not part of the expansion tank.
Pete
1997 Carrera S
2011 BMW 328I
Old 01-12-2012, 07:24 PM
shogun's Avatar
Robse,
just for info, how long was that thermostat installed? Years or miles?
Looks pretty familar to me from cars I had to work on.
On my own cars I change them every 3-4 years latest as preventive maintenance. T-stats are not expensive, but they can cause expensive damages when failing, so better replace early enough.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 02-10-2012, 08:08 PM
