E39 Front and Rear Window Trim Replacement
I will soon own a E39 that showed deterioration of both front and rear window trim. I see that PP stocks the trim for the front window. Is it the same for the rear window and is this a fairly easy job that does not require special tools?
http://forums.pelicanparts.com/uploa...1333152248.jpg |
It isnt the easiest to remove the trim without bending it. The front trim pieces will not be the same as the rear.
If you give me your VIN, I can look up the correct pieces for the rear. |
| All times are GMT -8. The time now is 04:01 PM. |
