2005 BMW 525I. Replace front and rear pads and sensor wires..Plugged and un-plugged rear sensor wire several times. Has message and won't reset.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing BMW Brake Pads |
You have to replace the brake message through the instrument cluster on iDrive.
Use the toggle to navigate to the warning message, then reset my pressing and holding the BC button on end of turn signal stalk. Look under info sources in the iDrive menu - Nick |
| All times are GMT -8. The time now is 05:10 PM. |
