| plutto |
09-21-2014 11:12 AM |
94 525it trans program +
i changed the automatic trans on my 94 525it it is full of fluid however when i shift to drive and pull off it pulls off normally but when its about to switch to 2nd it bumps a little then then trans program display comes on and the led lights for p r n d goes out before it would gradually get up to speed and i drove it on the highway it seemed to be running fine but when i come to a stop then try to pull off again it will pick up slowly now .when i shut of the car wait a few minutes and start it again it pulls of normally in first and when it gets ready to switch it has a little bump like in the trans not a grinding noise and then trans program comes on and the p r n d led goes out. took it to a bmw guy with a scan tool and he said everything checked out. he said with a new battery should clear up any faults since the battery had a dead cell i got a new battery same problem.
