-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Intermittent Starter motor terminal 50 fault E60 525d (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/945976-intermittent-starter-motor-terminal-50-fault-e60-525d.html)
Talisman89 (guest) 02-14-2017 09:41 AM
Hello i have bmw e60 525d.automatic. trying to start engine, starter works for couple seconds and then stops. Takes about 5-10 times pressing start up button to start up engine. Glow plug control been changed.
Some times have fault code: starter motor terminal 50
Can you give me advise, please?
Thank you.
This post was auto-generated based upon a question asked on our tech article page here: BMW E60 5-Series 6-Cylinder Engine Starter Replacement (2003 - 2010) - Pelican Parts Technical Article
Casey at Pelican Parts 02-14-2017 09:41 AM
Sounds like you have a communication issue with your CAS to DME. Best to have the professionals tackle this one as special diagnostic equipment is required. Prior to doing that though...I would replace your battery.
- Casey
