07 bmw525 intermittent leak when running. I pulled the bottom cover off and can't seem to locate the source. even running, the leak isn't consistent. any ideas ?
__________________ This post was auto-generated based upon a question asked on our tech article page here: BMW E60 5-Series Cooling System Leak Test (2003-2010) - Pelican Parts Technical Article |
Yeah I have found that its easiest to find the leaks on these cars if you pressurize the system using a pressure tester and cap adapter WHEN COLD. The thermal expansion tends to seal up the leaky areas as the car warms up.
- Casey |
| All times are GMT -8. The time now is 08:48 PM. |
