-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Testing ABS Wheel Speed Sensors (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/960122-testing-abs-wheel-speed-sensors.html)
rsinuc 06-14-2017 06:05 AM
Something I found useful if you are testing the individual wheel sensors is to slip a length on 1/16" copper tubing over the pins to extend them outside of the sensor plug and permits better checking in the sensor with a VOM.
Dmitry at Pelican Parts 06-14-2017 09:14 AM
Thank you for sharing this info, I'm sure other members will find it useful.
rsinuc 06-14-2017 10:17 AM
Thanks, Dimitry, can you check my ABS Error code post and see if you can give me any info re error code 40 from ABS model. What is the "gas valve"
Dmitry at Pelican Parts 06-15-2017 10:55 AM
No problem, glad to help! Unfortunately I wasn't able to find much info on code 40 - Gas Valve - Potentiometer Error. Hopefully some other members will chime in.
rsinuc 06-15-2017 10:59 AM
abs error code
I think it is the pot on the secondary throttle butterfly for traction control.
