Parts Catalog Accessories Catalog Tech Info Tech Forums
  Search our site:
 Cart  | Project List | Order Status | Help
1998 528i no power to Secondary Air Pump
Hi all,
We have a 1998 528i that shows a DTC, I forget the #, but it points to the Secondary Air Pump. There is no power going to the pump. If I use an external 12V applied to the pump it runs. Does anyone know if the pump is supposed to run all the time? I didn't find any bad fuses, but I also didn't find any fuses labeled, Secondary Air Pump. Is it controlled by a relay?
Thanks for your help!
John
MJ & JJ
Old 03-02-2007, 11:54 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Jeron's Avatar
It only comes on for a short while at startup. It has a relay and that is the next thing to check. You need a Bentley for the E39 or search the web for the relay location or try the main power distribution box and see if it is listed on the lid.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-02-2007, 01:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Jeron's Avatar
Use this:
Electronic Shop Manual
Go to the Automotive section then select your car then Wiring Diagrams.
Old 03-02-2007, 01:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
did some more checking over the weekend...
There is a valve/switch installed down stream of the scondary air pump. It is vacuum operated. I followed the vacuum line to a switch mounted between intake runners 1 & 2. I'm guessing that when the switch is activaed it lets vacuum pass through to the valve/switch downstream of the secondary air pump. The plug that goes into the switch did not have power when I checked it. Does anyone know when this switch is supposed to be activated? ( it may be called the Back Pressure Valve) And what activates it? We do have vacuum to the switch.
There was info on the switch:
7 22341.00
12V 98T145
1 742 712
Pierburg
PA6 GF30
We are still trying to find out more about how this whole system works.
We are also trying to identify which relay and/or fuse controls the secondary air pump.
Any info would be appreciated however small it might be.
Thanks!
MJ & JJ
Old 03-05-2007, 11:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
the valve has nothing to do with the power to the pump. if no power, check the wires, if they are good, check the relay
gONe
Old 03-07-2007, 08:51 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
