Parts Catalog Accessories Catalog Tech Info Tech Forums
  Search our site:
 Cart  | Project List | Order Status | Help
Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39
JMI JMI is offline
Junior Member
Ignition coil and idle\stall problem
1989 535iA - M30 Engine
Been beating my head over an idle that runs fine (700 rpm) then suddenly will drop a few hundred rpm and at that point either stall completely or surge to 1100-1200 rpm before dropping back to 700 rpm. Have inspected all the usaul suspects.
Could a bad ignition coil cause that sort of problem?
Jim
Old 09-07-2006, 07:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Living on borrowed time!
JonyRR's Avatar
air leak?
if it settles down when warm, I say air elak.
Better a has-been than a wanna-be
'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'.
Old 09-08-2006, 12:20 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
JMI JMI is offline
Junior Member
Have looked for vacuum leaks - don't see any. TPS & ECT & CPS & AFM all check out. Have changed ICV and distributor and rotor. I'm at a loss.
Oxygen sensor ihas only 18000 miles on it.
Beginning to suspect fuel problem, but tired of throwing parts and money at the problem.
Help!
Old 09-08-2006, 05:10 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
JonyRR's Avatar
'looked for vacuum leaks'
did you try the propane (or contact cleaner) test;
run engine, spray cleaner or propane around the usual suspect points, listen for idle to change.
Old 09-15-2006, 02:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
JMI JMI is offline
Junior Member
Idle Problem Fixed
It turns out the problem was a bad pulse generator/cylinder ID sensor: see #9. This is sometime included with new plug wires but check to make sure it is. They should be changed together at a regular interval, say 50,000 to 100,000 miles.
The car drives like a dream now
Old 10-19-2006, 02:57 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
