540i Viscous to electric fan conversion
Anyone done this by any chance? If so I'd like to know if the shroud has to go - I'm looking at a 17" fan which may or may not fit within the existing shroud. (Can't measure it at the moment because there is a 1000 or so km between me and the car) I suppose the main reason for keeping the existing shroud is that it has hose fastenings etc as part of it's structure.
I just picked up a 95 540i Sport and this is on my short list of things to do. Keep the shroud, it helps with the efficiency of the fan and reduces hot spots in the radiator core. I'll post back a reply when I get the pieces together to do the swap. Here's a pic of the new ride...
![]() BMWmech1 Last edited by bmwmech1; 04-25-2009 at 05:17 PM.. |
OK I'll wait until you know more. Do you know the diameter of the existing fan by any chance?
Many thanks! |
I think I can answer my own question on size. According to Pelican Parts a replacement fan is 18" (450mm) and the fan I am looking to fit is 429mm - so it should fit in within the existing shroud fairly easily.
The shroud is unnecessary for the electric fan but keep it to route the hoses etc.
Make sure to measure the max depth. If you have to go with a 16 or 14" fan you will be fine. The electric will pull a lot more air than the mechanical fan.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2001 330i Silver/Grey ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l Gone: :'( 98 Camry V6 97 Camry I4 97 Mazda 626 I4 :'(93 Sentra SE-R 88 Toyota Truck I4
I will respectfully disagree with Jeron's reply that the shroud is unnecessary... The fellows at Zionsville agree with me, as well, and they do BMW cooling better than anyone. If the shroud were not necessary, there would never be one installed on any car, viscous or electric fan setup. Yes, the electric will flow much more air, but why remove the shroud? It definitely helps with airflow and efficiency and BMW added it for a good reason. Not trying to start an opinion war here, just saying that there would be no good reason to remove the shroud, so why do it? Even if I decide to run a dual 12" setup, which I may, I will fab a new shroud... just no good reason not to...
![]() On a separate note, the 17" or 18" single fan will work in the factory shroud... verified it today at my shop. The core is roughly 26" wide and 19" tall, so a dual 12" is possible, but nothing bigger for a dual, unless you staggered a pair of 14"s, but it makes fabbing a shroud more difficult. BM1 |
I did not suggest removing, there is no reason to.
The stock shroud is necessary for the viscous fan because it is so far from the core. Without the shroud the viscous fan would not pull air through the core. The electric fan sits less than 1/2" from the core and has its own mini-shroud, so the stock shroud is unnecessary. You can make the electric fan more efficient by covering the entire back of the radiator. However if you do this with a small fan you will loose cooling capacity at speed.
![]() BM1 |
Just measured it, it's 3.5" from the back of the core to the front of the waterpump threads. Plenty of room and you could offset it slightly away from the pump centerline to gain more space, if needs be...
BM1 |
I havent seen the shroud on this car. If the fan does fill the entire open space of the shroud then yes it will certainly work and be beneficial.
The shrouds I have seen are about 3 inches deep and the electrics fans used are usually only a couple of inches thick at the sides. In addition, you usually cant fit a fan the same size as the shroud opening because the pump threads interfere with the electric fan motor. Typically you have to get a smaller 16" or 14" fan and offset it on the core. It's these smaller offset fans that make the shroud meaningless. Feel free to reply. I enjoy the discussion.
