Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Trailing Arm Bushings
94 525i E34 M50 Sedan
I have seen replacement bushings with eccentric and without. Is it advisable to replace the old stock bushings with an eccentric bushing for rear wheel alignment? I am replacing suspension parts as a project over the upcoming winter and am stock piling parts as I can afford them.
I use the vehicle for basic transportation only; no racing, etc... Just for comfort.
Thanks, Norm
Old 08-21-2009, 09:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Update
Upon researching the use of eccentric bushings, I found threads on other BB related to the use of eccentric bushings when lowering the suspension. You can find further discussion of this topic by entering your query under that topic.
Using eccentric bushings in direct replacement of standard bushings presents a problem of adjustment. It appears that the eccentric bushing must be pressed in to the correct offset for the adjustment to be correct. (How you know what the correct position is becomes the problem.) If it is not correct, the bushing must be pressed out and repositioned. A major hassle unless you like that sort of thing.
There are other systems available that allow for easier adjustment. I am not lowering my suspension and had no intention of doing so. Lowering a suspension in an area of winter climate would be rather silly. Plowing three inches of snow with the undercarriage when I can ride above it makes no sense.
So if you have no intention of lowering your vehicle, stick with the standard bushings.
Old 08-26-2009, 04:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Ben@euromechinc
Sound advice, why add an adjustment if you don't want to adjust it?
Old 09-22-2009, 02:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
