Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
samuraj's Avatar
01 530 radiator ?
I`ordered new radiator, can some one , walk me thru replacing......easy way?
how hard is to remove upper hose? (I took clip out, but connector did not move )
do I have to remove cooling fan? (look like not )
P.S.my radiator #2 cracked by the hose neck! again!!
2001 530i black
2005 dodge ram hemi sport
P1445 Big Hawg
Old 10-05-2009, 05:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Jeron's Avatar
I dont know the easy way. Removing the fan will probably make things easier but removing the fan is a bit tricky.
If you dont do much of your own maintenance very often I would go ahead and replace the belts and hoses while you have it apart.
I am certain you can find a radiator replacement thread specific to your model on the web.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2001 330i Silver/Grey ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l
Gone: :'( 98 Camry V6 97 Camry I4 97 Mazda 626 I4 :'(93 Sentra SE-R 88 Toyota Truck I4
Old 10-05-2009, 06:37 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
samuraj's Avatar
hoses on 2001 have spring lock connectors, not drive clamp. how much force need be applied to remove hose? is there any "O" ring inside?
2001 530i black
P1445 Big Hawg
Old 10-06-2009, 05:50 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Jeron's Avatar
This basically the same as your but not exactly. Yours is also basically the same as an E36.
Undo the clamp, slide t down the hose out of the way, then twist/pull the hose off.
Old 10-07-2009, 06:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
samuraj's Avatar
upper and lower hose does not have clamps....only spring lock, and plastic connectors....
how I can remove them ?
2001 530i black
P1445 Big Hawg
Old 10-07-2009, 04:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Jeron's Avatar
If my definition of a spring lock is the same as yours, you wedge a flat head in it and twist. Then replace it with a worm drive clamp.
Old 10-07-2009, 05:39 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Jeron's Avatar
Is this it:
How do you remove/install these hose clamps ? - Bimmerforums - The Ultimate BMW Forum
Old 10-07-2009, 05:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
samuraj's Avatar
NO.... mine are different.
any way, my radiator arrived, time to check parts included in the kit.
maybe I can snap some pics later..
2001 530i black
P1445 Big Hawg
Old 10-08-2009, 05:38 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
samuraj's Avatar
officially my car has radiator #3
time to save many for next one....or down payment for new car??
2001 530i black
P1445 Big Hawg
Old 10-13-2009, 05:48 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
