-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   Ac compressor noise (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/1008389-ac-compressor-noise.html)
Guido1 09-20-2018 08:00 PM
Ac compressor noise
My ac compressor is making a squealing noise at start up.
Are the bearings going bad ??
Pulley ??
Belt ??
wfwright2 09-24-2018 06:34 AM
That description leads to a number of possibilities.
From your list, could be loose, worn belt or belt tensioner going bad.
Could be a fluid leak that wets the belt or pulley that gets cleaned off after a bit.
Could be a clutch or compressor bearing starting to fail, or a clutch bearing that has failed and shuts up when clutch is engaged (the AC compressor clutch of course).
Could also be power steering pump or water pump.
Could be a bad compressor or an overcharged AC that allows liquid refrigerant to get to the compressor.
Need more trouble shooting done.
Sent from my Moto Z (2) using Tapatalk
shogun 10-26-2018 01:18 AM
First of all tell us the 7 model, type, built year
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
