-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   Changing E28 subframe bushes (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/10117-changing-e28-subframe-bushes.html)
Steve Taylor 03-21-1999 09:12 AM
Apparently I need to change the bushes between the subframe carrying the differential and the main body of the car. I understand that one approach is to remove the subframe and take it to a 50 ton press. Just wondered if anybody had experience of any other on-the-car approach. thanks Steve
JP Noonan 06-04-1999 06:49 PM
I know this response is a little late coming, and even then not very helpful but...
If the bushing is like a suspension bushing and is not next to any sensitive equipment (i.e. gas lines or wires) then try torching it out. A small propane one should work fine. Then clean it out with some emory cloth and use silicon (don't use anything petroleum based) grease to install the new bushing.
