LinkBack | Thread Tools | Rate Thread |
2002 745i n62 oil pump chain tensioning
Update: a master tech told me the chains have a bit of slack so this is normal.
Good Day.
I have a 07 X5 4.8L. Timing Chains noisy and seems to be stretched chains and or tensioners worn. I could use advice on during this work while engine is in car. I liked your pictures 47162rallenby above. Can the oil pump chain be removed as shown in your pictures, or does the pump gear need removed fist and how to do that? thanks in advance. |
correction, I believe I have problems with my 07 X5 4.8L timing chains stretched and chain guides worn - noisy and different rpms/speeds and can hear noise through oil fill cap.
thanks again |
Thread Tools | |
Rate This Thread | |
Tags |
2092 745i , n62 , oil pump chain , tensioner |
