Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Angry Oil cooler line leak
Hello all,
I have a 2007 BMW 650i/E63. I recently changed the infamous alternator bracket gasket as well as 2 O'rings that go on the oil cooler lines which connects to the thermostat that attaches to the alternator bracket (I attached 2 pictures). I had to perform this job twice and both times it seems to be a very small leak coming from the aft line. At first I thought I did not TORQUE the bolt down tight enough or that the lines were cocked. second time around I made sure I loosened all the lines, ensured the O'rings were installed correctly and really took my time with the job ensuring I did not miss anything. Unfortunately I still have a very small leak. I torqued the bolt down as tight as I could with an Allen key. Has anyone ever had this problem? Is there something that I am doing wrong. At this point I cannot understand why there is a leak. Should I try and torque it down with a hex socket and ratchet? I did use a lot of force with the Allen key and the bolt did not move.
Can someone please help or shed some light. I am getting frustrated.
Thank You
Old 10-08-2019, 05:00 AM
