Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
1992 735i Hazard lights
The hazard lights have a mind of there own. They will come on blinking for 3 to 8 minutes and go off. It doesn't matter if the car is running or not. The only way I have found to stop this problem is pulling the fuse which also kills the direction signals, not a good solution. Does anyone have any ideas?
Old 10-31-2003, 05:02 AM
KC Ron Carter's Avatar
Here is a wiring diagram link
http://www.autolib.diakom.ru:8001/CAR/BMW/1992/735i/WIRING%20DIAGRAMS/64.pdf
Later,
Old 11-12-2003, 06:05 PM
I have a 91 735i and have found that the slightest pressure on the switch will activate the flashers. I suggest possibly taking the switch apart and cleaning it or replacing it
Old 11-13-2003, 01:44 PM
I have tried replaceing with a used switch but no help, I will try a new one and see if that solves the problem. Thanks for the help
Idus.
Old 11-23-2003, 10:57 AM
Hi,
I had a recent problem with this and found that I had water getting into the electrics above the glove box.
Being a British car, that means the left side of the car.
The water was getting in through a perished rubber bung which was situated under the bonnet/hood of the car near the fuse box.
Between the fuse box and the wind screen/shield there's a grill that the wipers pass though, under this grill is where the rubber bung was.
I used some water proof silicon stuff to seal it again.
Regards,
Adrian.
Old 11-27-2003, 06:14 AM
