-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   lost first and reverse (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/288103-lost-first-reverse.html)
85_635csi 06-13-2006 08:28 AM
COming home from a road trip (Vintageatthevineyards)
My 1985 635csi lost reverse and first gear (5 sp dogleg)
I fisrt thought it was some shifting (engine or center bearing but both seem sound.
Am I in for a new trans or is it just linkage ....
Mark
radm635 06-14-2006 10:17 PM
Check the oil in the trans for any excessive metal... that might give you a bit of an idea. The linkage is pretty easy to deal with on these cars and if you have a lot of wear on the shift lever bearing or a problem with the streight selector rod then that might be it. However, if I remember correctly, I do not believe that there is any internal link between 1st and and reverse. Do you know if yours is a Getrag 280? Is reverse to the left and up?
