Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
frank1020's Avatar
1088 735iL
I don't have a repair manual yet but was wondering if someone can tell me where I would find the Hot Water Valve. According to the dealer, this valve regulates the heat and A/C in the vehicle. Right now, Half of my vents blow cold A/C, the other half blow warm to hot air. I am trying to replace the valve but first i want to see what it looks like.
Tks,
Frank
Old 07-10-2006, 09:51 AM
Send a message via AIM to Bear
Heat and AC
The water valve or auxiliary heater valve is located in the engine compartment, bolted to firewall just in front of driver. There is a plastic cover over the valve and hoses and taking off the cover exposes the valve. If you have a B+ remopte jumper post for jump sytarting the car this valve should be next to the B+ post.
Old 07-14-2006, 12:14 PM
frank1020's Avatar
Yes, I found it. tks
Old 07-14-2006, 12:17 PM
Heat and AC
Go to www.bmwe32.masscom.net for a better explanation and picturres of this valve.
Old 07-14-2006, 12:19 PM
frank1020's Avatar
That link doesn't seem to work. Do you have another?
Old 07-14-2006, 12:21 PM
735
Try it this way
http://bmwe32.masscom.net
Old 07-14-2006, 12:57 PM
frank1020's Avatar
That was it. This is perfect. The pictures look like the valves on my car.
tks
Frank
Old 07-14-2006, 01:29 PM
