Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Question DEAD E38 750iL
just bought this E38 750 ran when I brought it home and not it would not crank, turn the key and nothing happens what could it be ?
some one said it need a motor but I dont buy it and where in the hell would I find such a motor ?
Old 07-11-2006, 05:49 PM
Send a message via AIM to Bear
No Start
I would start at the battery. You can hook a volt meter to the B+ jumper post in engine compartment (in front of driver and should have a plastic cover on the post with a B+ on the cover, the post is hexagonal in shape). Put + lead to this post and - lead to a bolt on strut and take a reading, you need to see at least 12.0 VDC. This is also where you jumper the car, you can get her junperred and when running take same reading and you need to see at least 13.5 VDC if the alternator is good.
Old 07-14-2006, 12:18 PM
yes I have the correct Voltage at battery but it seems like the immoblizer or something is stopping it from starting
Old 07-14-2006, 01:22 PM
battery fully charge now and all I get is a clicking
Old 07-20-2006, 06:06 AM
No start
If the battery is fully charged and the engine will not cranks i would suspect the starter or starter solenoid is bad.
Old 07-20-2006, 06:42 AM
battery is replaced and now it started but a loud knocking from the engine and a puddle of oil on the ground
Old 07-20-2006, 11:01 AM
anyone knows where to find a reasonable priced motor ?
Old 07-20-2006, 11:02 AM
No Start
Start at BAVARIAN engine recycling www.bmrparts.com they rebuidl and warranty BMW engines.
Old 07-20-2006, 11:20 AM
you just bought it? whats the mileage? why didnt you get a PPI?
a motor in that car is going to probably cost more that it would cost to replace the car.
:::http://www.bmrparts.com/engine1a.htm::::
750il 95-97 v12 MaxSil™ 1742250 / Tefcote™ $10,775 $12,335
I would rasie hell with the seller. ESPECIALLY IF IT WAS A DEALER.
so was it a dealer?
Current: 1973 914/4 project. FOR SALE
Old 07-23-2006, 11:13 AM
so was it a dealer?
yeah I did raise hell but nothing I found a parts car 98 750 il so anyone need anything let me know
Old 07-23-2006, 11:11 PM
Rad Hatter's Avatar
Try an 850
Buy a cheap 850 with a sound engine.
they are going CHEAP
I know one for sale in the UK
ita an M70 engine same as the 750.
I reckon you could offer him 4k pounds and then sell off the other bits off the car as scrap on ebay.
Drop me an email if interested.
Euro 1989 Carrera 3.2
Paint Code L 693 Stone Grey
45,000 kms logged
Old 08-31-2006, 01:49 AM
Sorry to hear this 7fiddy. I have a 850i and these engines are bullet proof unless you overheat one. I would find out where the oil is coming from first. This sounds a bit fishy. Engines don`t blow sitting in the garage they normally blow at redline. I would also ask the person that said you need a engine how he came up with his conclusion, did he do a compression check, oil pressure check, is there a hole in the side of the engine. I would like do know what he based his opinion on.
Regards,
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi
Old 09-14-2006, 10:09 AM
