-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   help with dyignostic codes (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/374133-help-dyignostic-codes.html)
mistro1 10-26-2007 07:38 AM
I have a 735i 1991se bmw which shows up with fault code e36 witch relates to torque converter lockup clutch can anybody explain what this is many thanks mistro1
Jeron 10-26-2007 08:48 AM
Look up torque converters on How Stuff Works and Wikipedia.
It sounds like you can just pull the tranny and replace the torque converter which should be a job similar to a clutch replacement. At least similar in difficulty. It may be possible to have it rebuilt.
mistro1 10-26-2007 09:47 AM
many thanks jeron will try your suggestions mistro1
