-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   92 735i ignition switch problem (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/388826-92-735i-ignition-switch-problem.html)
porcha 01-23-2008 04:35 AM
Can someone post the how to on removing the ignition switch. Does this sound like the electrical side? Or is it the mechanical side. The key turns but nothing happens.
Yesterday, after starting the car everything was fine. When I got home. I turned the key to off and the car was still running. I had to pull the fuel pump fuse to stop the engine.
Charles
Jeron 01-23-2008 08:19 AM
I've seen some DIY articles on ignition switch replacement. You should be able to find them on the web. Don't limit yourself to 7-series though, try BMW, E36, E46 too.
phlytrader 01-29-2008 07:12 AM
Try this link.
http://www.e38.org/e32/
They have lots of articles.
porcha 02-15-2008 08:31 AM
switch
Thanks Guys, I decided to take in to the shop. they changed it out for me.
