Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
18wheelerbob's Avatar
Flasher Relay works on and off....
Hello folks is me again, driving normal down any street and then wanting to make a turn my signals lights decide not to work/stopped working, but then I've notice it also affects my brake lights and wipers? It comes and goes I'm ready to give the up! I personally think I have a wire that's shorthing out somewhere or my main computer is going? Please help or make me an offer for the car I give up?
Old 05-17-2009, 05:41 AM
Hi sounds like a short? However first check that the flasher relay isn't on it's last legs, hopefully cheap to pick up where ever you live. Get that done 1st then if not you'll need to try the elimination process, make the task interesting not a pain in the you know where. Good luck
Old 05-24-2009, 01:43 AM
shogun's Avatar
in case that happens on the E32, it is the crash alarm relay/crash control module which sits in the fuse box next to the LKM
http://www.nmia.com/~dgnrg/page_22a.htm
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 06-04-2009, 04:27 AM
