GM reset and installation procedure
dated January 1992. It incorporates additional
information on the new General Module software for E32/E34 vehicles. Please remove and discard S.I. 61 01 92 (3460) dated January 1992 from your S.I. Binder. SUBJECT: New General Modules (GM) MODELS: 7 Series (E32), 5 Series (E34) - Vehicles produced 9/91 and later Situation: New general modules have been used in production since September 1991 in all E32 and E34 models. The software has been completely revised (details of these revisions are found in the attachment to this Service Information Bulletin). Part numbers have been changed to reflect these revisions, as listed below, as of September 1991. Model Part Number E32 61358356095, E34-up to 61358356095 9/91 production E34-9/91 and later production 61358355812 Note: E34 vehicles produced 9/91 and later have different central locking system components from earlier E34 vehicles; therefore, P/N 61358355812 is used only in E34 vehicles produced 9/91 and later, P/N 61358356095 can be used in E34 vehicles produced prior to 9/91, and in all E32 vehicles. When the general module is connected to the vehicles electrical system, it will recognize (and store in memory) the vehicle configuration, such as: - with/without power windows - With/without power sunroof - with/without wiper contact pressure control - with/without headlight washers IMPORTANT INFORMATION ===================== All general modules must be plugged in only after disconnecting the vehicle's battery. If the vehicle's battery is connected when the GM is installed, undefined signal contacts can cause an incorrect vehicle configuration to be stored, resulting in the impairment of one or more of the above-mentioned systems. If one or more of the GM functions are impaired in this matter, the GM can be "cleared" by disconnecting the vehicle's battery for at least ten seconds. Warranty Status: Information only. Attachment to S.I. 61 01 92 (3460) GM Function Changes E32/E34 (Beginning with 9/91 Production) - Repeat and Time interlock for headlight washers: · Time interlock: 3 minutes · Headlight washing at fifth windshield washing after time interlock. - Intensive washing pump operating time reduced from 3 to 2 seconds - Minimum interval for intermittent wiping is programmable down to 2 seconds (previously 3 seconds) - Increased wiper contact pressure during windshield washing cycle is now also provided during dry wiping portion of the cycle (previously only during washer pump operation). - Previously, the GM would react to opposing signals (eg., an unlock signal while trying to lock, as with a defective microswitch) by carrying out the first command, then the opposing command (e.g., locking, followed immediately by unlocking). Repeating the first command then results in carrying out that command (e.g., try to lock again, and locking is now carried out). This function ("Asynchronous Position") is omitted in the new GM for all E32 models and E34 models prior to 9/91 (P/N 61358356095), and remains in the new GM for E34 models after 9/91 (P/N 61358355812) only for central locking commands "lock" and "double-lock". - After unlocking is performed due to crash sensor activation, the locking command is now reactivated by double-locking with the key from either the driver's or passenger's door. - The "one-touch" operation of windows has been expanded to include all four windows in the opening direction. The driver's window still has "one-touch" operation in both opening and closing directions. Interruption of the "one-touch" feature of the driver's window in the closing direction is still accomplished by depressing any window switch (in any direction), or by depressing the sunroof switch in the "tilt" direction (provided the sunroof is not already in the "tilt" position). Interruption of the "one-touch" feature of the sunroof in the closing direction is still accomplished by depressing the sunroof switch (in any direction). - The switch-off delay of the interior lights which occurs after entering the vehicle and closing the driver's door has been reduced from 20 seconds to 15 seconds.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES http://twrite.org/shogunnew/topmenu.html |
