Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
bmw 733i 1984
cannot get car to stay running changed fuel filter still nothing
Old 10-23-2009, 06:26 AM
shogun's Avatar
what to be checked
That is for all E32, so some items your car does not have:
1) Spark plugs, plug wires, distributor(s), distributor rotors),ignition coils - Clean and inspect.
2) Check compression – poor cylinder head compression is common for an older car. Big job to fix this.
3) Use a good fuel-injector cleaning treatment into the tank – take it for a good run.
4) Change fuel filter.
5) Remove and clean injectors – might need to replace injectors.
6) Hose to fuel pressure regulator – might be cracked/worn (buy a new one)
7) Rubber hose between Airflow Meter and throttle – cracked?
8) Mass Airflow meter/sensor – if dirty clean it up. Bad Air Flow Meter will cause flat spots in acceleration or erratic spots in the throttle depending on the opening of the airflow meter not usually a complete lack of power.
9) Hose to air filter – cracked?
10) Air filter – replace if dirty, check seals.
11) Distributor cap – if eroded and worn - changed to new one
12) Check fuel pressure - Replace the Fuel Pressure Regulator. Might need to replace Fuel Pump.
13) Check and Adjust valves - throttle valves, PCV valve behind intake runner, Idle Control Valve (ICV).
• ICV Idle Control Valve. Remove and clean it with brake parts cleaner. This regulates the air coming in to your intake manifold when the throttle body is closed and it tends to get dirty, sticky and the motor inside could not turn the valve properly.
• Idle control valve sometime sticks open – causes issues when in Idle
14) Throttle Body - Clean it out and replace the gasket (can use gasket material cut to size).
15) Check all Vacuum lines.
16) Conduct a ‘leak down test’ on all exhaust valves.
17) Check for Oxygen (O2) sensor function tests.
18) Check the wide-open throttle switch under the gas pedal.
19) Check throttle position switch on the throttle body.
20) Make sure connections on battery (under back seat) are very clean. Use wire brush.
21) Check rubber boot between the Mass Air Flow and the DKM.
22) Check for intake manifold gasket leak
23) Have the transmission checked for correct functioning – (by mechanic).
24) Make sure there are no other sources of drag in the driveline.
25) Check coolant sensor.
Try the RESET Procedure before all of above.
Notes:
The reset procedure is billed as a ‘cheap fix’. It does often give good immediate results, however if there is something wrong with your car (any number of issues as listed above) then over a 2-8 week period the car will likely return to its original state.
The reset procedure removes all mean values stored by your onboard computer that control engine timing, fuel use etc. As you continue to drive the car, the stored values ‘average out’ to best suit the engine condition.
If your car has for example a leaking intake manifold gasket or broken O2 sensors, the readings are quickly going to become ‘corrupted’ with incorrect information. This can lead to the engine running too rich or too lean (check your sparks for evidence). Within a short period of time the car will return to rough idle as the underlying problem has not been fixed. That said – the reset procedure can reset values that are no longer applicable. You may have replaced something on the car (e.g. Catalytic Converters) thus causing a sudden change in normal engine running. The readings stored over 10-20 years will suddenly not suit you recently modified car. The car will however read new values in and average out over time. The Reset procedure simply speeds that process up.
The long and short of it is that this procedure can sometimes fix rough idle and transmission timing and seems to improve the cars performance. However with existing underlying issues as outlined above – it won’t be long before the problems return.
Procedure:
1. Disconnect battery cables, first negative, then positive.
2. Cover and protect the battery posts! Leave no potential of a battery short circuit.
3. Turn ignition to position II.
4. Connect both battery cables ("SHORT") for at least 10 minutes. This step drains a capacitor in the ECU/TCU. (Covered the battery with a thick, dry shop towel to prevent actually shorting the battery! – careful of arc welding in my back seat! As the battery was in place, and the cables aren't that long, you could use a very long Craftsman screwdriver and two small vice-grips to actually clamp the negative and positive cables to the metal shank of the screwdriver.
5. Wait 10 minutes - then ignition off, key out.
6. Reconnect battery positive, then negative.
7. OBC says "PPPP", reset time. Start and idle the engine for 5 minutes, then off for five, then out for a drive.
8. Now, with the car in lowest gear (one or two depending on your make), accelerate until at least 5000 rpm is reached (only M70 engine). Allow the car to slow to idle, and then repeat two more times. Let the car idle for 5 minutes. All Done!
9. Idle should smooth out over 10-12 miles; shifts should be immediately smoother.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 10-24-2009, 04:47 AM
