Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
750iL Front Passenger Door Electronics
'01 750iL - All electrical controls on the front passenger door have stopped responding Locks & Windows. I am inclined to believe this is a fuse, wiring or harness connector issue since all stoped at the same time.
Are there fuses to this one door? Where does the door wireing harness run to. Is there a single plug connector that if unplugged would cause this fault.
Tried to find a wiring diagram for the car in the BMW TIS, no luck. Anyone know were to get a diagram or have a suggestion on this issue?
Old 08-28-2010, 09:02 AM
shogun's Avatar
best is you get a Bentley Repair Manual for the E38, the bible for the owner.
If it would be an E32, I would recommend to check for broken wires in the wire loom between A-pillar and door, 2 screws hold the rubber boot and in many cases the wires are broken after so many years movement.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 09-12-2010, 08:05 AM
